drunk on diesel
- Joined
- Sep 7, 2011
- Messages
- 4,179
- Reaction score
- 0
yeah, no... I'd get back in a Dodge before I got into one of those piles. And that's saying a LOT because I think Dodges are piles!
what other extreme heat scenarios? at high RPM/load while towing?
I believe the theorem is that it's not a problem at higher RPM because the inertia of the valve is able to overcome the friction.
It's at lower RPM that it occurs, correct?
regens(on dash notifications) take up to 30 min. that is the reported time this is happening correct? when else does it reach that heat and back pressure for longer than just a couple minutes?
btw, im not arguing one side or the other. im just trying to wrap my head around both sides of the stories..
this reminds me of what happens on the ole 7.3 when one uses the ebpv as a brake with stock valve springs. back pressure holds valves open...
as i stated, it just reminded me of the back pressure holding valves open on the 7.3s..
i dont have the problem, im just trying to understand whats going on.. it may be valvetrain slap and not hitting the piston.. if its a tuning tweak, what is being tweaked to remidy the issue?
live life full throttle
i did too.. if you drove like i do, 8 bent pushrods later down the road, it messes them up.. my first rebuild showed valve marks on all pistons.I used the EBPV a ton when I towed with the dually. Never knew there was an issue with that?
no.. i have the old powerstroke power braker.. flip a switch to activate it and when you lift off the throttle and applied brake pressure, it automatically closed the ebpv.. as soon as you touched the skinny, it opened back up.. i ment how i drive on a daily basis with my dually.. pretty much wot everywhere i went even when towing.. no matter the load...Forgot the brake on and gave it throttle? Lol
To explain what happens a bit more....
Can you explain why replacing the head or valves makes the problems go away?
Sure, the trucks that have this happen have guides that have inside diameters that came thru smaller than they should be. When the valve stem is inside of it, there is not enough room between the stem and guide to accommodate the normal film that builds up on stem due to exhaust gasses escape venting up that guide any and all times the exhaust gas back pressure exceeds atmosphere pressure, which is normal for all engines, AND still have adequate clearance to additionally accommodate the expansion that occurs due to a $7 and change valve and this guide gets blasted while the valve is open during the exhaust stroke with extreme heat from the injector firing on that stroke.
This valve has a spring trying to pull it closed while open.
When the thermal expansion reaches its max, it causes what known as thermal expansion stiction.
Thermal expansion is not a "seizure" in the classical sense.
It is "stuck"
While in this static state due to this stiction, the spring still has stored energy within itself trying to pull that valve closed.
It is on the razor line of remaining in this static state and having the spring pull it closed.
Because it's on that razor line, it offers little resistance to the piston pushing it out of that static state.
Due to the valve offering little resistance to this combined with the valve geometry used, a straight up motion, the piston puts virtually no lateral force on this valve, which would be a catastrophic event immediately, this is not the case with the 6.7 and is why besides the violent bucking and no power, it tolerates this for a while.
Yes down shift, giving it fuel, or letting off changes the thermal dynamic thru air flow, fuel flow via different injection duration and injection event counts. Lots of variables and things change the thermal dynamics which only are holding that valve back from closing due to the stored energy in the spring. (Little resistance)It depends on the exact truck and how much resistance is offered. This is why a few cannot manipulate the event and get out of it at all if the resistance is more substantial.
