25% discount on ford parts to members
johndeerezach
wellman,IA
need a price on the 3 screws that hold the fuel neck on to the bed side and the rubber little bumpers that stick in the bed so the fuel door sits flush with the bed. thank you.
Ad8 PRODIGY
Orange County, NY
Yeah right? It wont fire up hot unless its jumped for a hair more powah. Have a feeling the
pump weep hole is sucking in air thru the weep hole when its hot after I shut it down... leaks fuel too there
Cough, electric fuel.
Cough, wanna buy it? I haven't decided if I want to drop coin and go that route. School just started back up so I'm back in saving mode since I'm not at work all day anymore.. lol
TrailerHauler
Michigan
I would at least price the stuff out for the swap, figure out if its worth it to you. Might be, might not be, but those mechanical pumps suck! I always say when stuff breaks, that's the best time to upgrade. LOL
Ad8 PRODIGY
Orange County, NY
Yeah me too. Unless its me ponying up the dough LOL
Exactly what I'm doing tho, pricing out the mech. pump and shooting a friend a text tomorrow to see what he paid, we just did his e fuel system when his motor was out
sunrisefordparts
screws list $1.33 each sell $0.80 each
bumpers list $1.50 each sell $0.90 each
free shipping
q#299952
Ace_boy2786
New Port Richey, FL
Can you (I) get replacement door stickers for vehicles? if so, say I had the vehicle painted, would I be able to get one with the new paint code(s)?
1999 F150 (Last 8- XNC3 6239)
Brakes (pads and rotors) (something quiet if possible)
Brake lines (braided/stiffened?)
some kind of light leafs and full-duty airbags? (even possible?)
DRL Relay and Resistor (Not a universal accessory/add-on)
2005 F350 (Last 8- 5EC9 2855)
DRL Relay: 2C3Z-13B218-AA
DRL Resistor: 6C3Z-14A601-A
I have autolights, does that mean I’d have the pigtails to plug these in, do you know?)
Updated HFCM plug
some kind of light leafs (axel locating) and full-duty airbags? (even possible?)
oil & fuel filters (not in bulk case, just 1 or 2 each)
2006 F350 (Last 8- 6EB6 2927) *out of curiosity, not sure of 18 or 20 mm*
everything needed for a Head Gasket job (please list parts)
2003 Windstar (Last 8- BB57 6673)
*interior Sticker: 125 0932 - MD DK GRAPHITE, Door Sticker: G2*
Pass door pocket
Pass seat right plastic cover
Thanks.
sunrisefordparts
Updated HFCM plug
Pass door pocket
Thanks.
heres your quotes for the first 3, the f150 show an add on kit for the drl but thats about all that avail, and for the light leafs and bags, leafs we could prob just rule out the code they have and go light but nothing on the air bag side through ford. windstar i need the correct vin, and need to know if there is a reflector on that door panel where the pocket is. head gasket job i cant think of anything else and im sure once i leave for the day something else for that job will come to mind but for the most part that would be whats needed, and i priced 18mm which is a little higher in price the 20mm hg.
  • Q300006.pdf
  • Q300007.pdf
  • Q300013.pdf
Ace_boy2786
New Port Richey, FL
I think the ford numbers are
relay block: YL1Z-13B218-AA
resistor: XL3Z-14A601-AA
For leafs, can you see what was stock? What would that run me? if not, where do I look for a spring code?
Thank You for your time, I'll probably be calling soon for a small order..
sunrisefordparts
the rear spring code if "f" for that model truck, im not sure what the weight rating is for those they sell for $209.32 each plus $50 for shipping. the yl1z-13b218-aa is an obsolete number though ford and not a dealer in the country has one in stock, the xl3z-14a601-aa changes to a 1l3z-14a601-ab sells for $49.19
morefuel
Chico, California
I need a quote for a 2005 f250 4x4:
Radius arm brackets for both the left and right sides, and i believe i will need a stabilization bracket with those also. Not sure if the 2wds use the same brackets.
Coil spring insulators.
Axle yokes front and rear.
slc dzl
Riverton, Utah
2007 f250 powerstroke 6.0
need a Ac compressor delete pulley assembly
a rocker assembly with both intake and exhaust and a the single rocker assembly exhaust side.
sunrisefordparts
lh bracket list $211.62 sell $152.36
rh bracket list $232.60 sell $167.47
stabalizer brackets list $19.78 each sell $14.24 each
spring insulators list $48.37 each sell $34.82
front flange list $64.15 sell $46.19
rear flange list $122.70 sell $88.34
would need vin to double check flanges upon ordering
free shipping
q#300386
sunrisefordparts
pulley assy list $100.55 sell $66.36
bolts list $2.00 each sell $1.20 each
rocker arm assy list $69.84 sell $52.80
exhaust rocker list $58.73 sell $44.40
free shipping
q#300389
