25% discount on ford parts to members
sunrisefordparts
Sorry, i need the whole dash piece for the cupholders as well. Part number 8c3z-2504608-ND i believe. Also in black.
the number you gave me with nd on the end is for the grey, the number ending in nf is the black list $178.85 sell $128.77
same quote
Ace_boy2786
New Port Richey, FL
out of curiosity what would all the stuff in this MKM Customs kit for 6.0L cost me?
From what I can tell it has:
Updated Turbo Oil Feed Line
Updated Turbo Oil Drain tube
HPOP Service/Update kit (with updates STC, O-rings, and IPR Screen)
DummyPlugs and Stand Pipes
Updated Degas Bottle Cap
Fuel Pressure Regulator Update Kit (I won't need this, Just for reference of kit cnontents)
also how about the oil fill cap? (mines looking a little chipped)
I'm not sure if the tubes and stuff come with the fasteners and o-rings and such, but the link shows them in the picture, so if it doesn't come with the parts how much for them too?
Thanks.
I'm trying to see if I should even attempt to do myself or spend the same or little more for less, I know it don't make sence but I'm not sure if I'd be able to do this myself.
sunrisefordparts
I also need bumper bolts but for a 2011.
Which bolts are you looking for.
Sent from my iPhone using Tapatalk - now Free
sunrisefordparts
Thanks.
heres the quote for that stuff in that kit.
  • Q301430.pdf
juniort444e
Slippery Rock, PA
I will call you. But I want to add more to the list..
Oil Dip stick
Ac pulley, the clutch is bad on mine
And a driver side door lock and a tail gate lock. the actual locking cylinders.
sunrisefordparts
What do you mean "built to my key" do you guys do it or do i have to do that?
Sent from my DROID RAZR
the cylinder comes all unassembled, so it is built to the code that your key uses, we could do it but obtaining a key code from ford is a pita. using a local locksmith or pulling your current cylinder and laying out the tumblers and seeing the numbers on each one is actually pretty easy to follow and do yourself.
