brian89
Tried putting it in 4 wheel drive and the light doesn't even come on, and it doesn't turn the wheels
Mine is doing that exact same thing again. I'm on my 3rd motor.Tried putting it in 4 wheel drive and the light doesn't even come on, and it doesn't turn the wheels
LOL! That brand is OE, I believe. It matched exactly with the original motor on the truck.Maybe if you are on your third he might want to buy a different brand LOL
Doc have you checked the lines with a multi and ohm it out etc. Make sure you do not have a ground issue that might be causing the motors to burn up. That and see how hard it is the manual move the level. Three seems like either really bad luck or something is up.
What did you use to check codes?I did check codes and i got nothing, but i haven't checked fuses yet and ill have to make sure the connector and wires are good, those connectors were hooked and unhooked quite a bit the past few weeks
