5th Wheel Towing w/ OBS
PsRumors
Cartersville, GA
Just installed my B&W Gooseneck and have my Companion, now starting to look for a camper.Trying to figure out how much I can tow. I see with 4.10s capacity goes up significantly, I am open to going to 4.10s.
What can these trucks tow in the 5th wheel configuration with 3.55s? With 4.10s?
Pstrke96
Dunnellon fl 34433
My obs Dually handles 12 k on the regular and 16 on occasion these days no major mods
In the past it tugged 16 reguraly now it's in semi retirement... Unless
Rykan tells me it "needs" a turbo and sticks this week then it's game on
Lol could get real fun real fast
JD3020
Farmersville/Dayton, Oh
I've grossed is in the 24-26k range a couple times with a GN on my OBS, 4.10's. Not sure what's legal though, seems like i found some specs a while back that said a DRW F-350 was rated to tow 13k.
gnxtc2
Bergen County, NJ USA
Here is a guide:
http://www.thedieselstop.com/faq/9497faq/geninfo/95ttg/16.php3
I've towed 22k with 3.55s but I have the HP to do it. The more HP you have, the less gear you need.
I would also check pin weight vs the rear tire capacity. I run 285s "E" rated tire which have a capacity of 3750ea x 2 = 7500lbs. If I had the stock 235s which are rated at 3042, I would have been over.
And get yourself some airbags for the rear.
Billy T.
[email protected]
PsRumors
Cartersville, GA
Here is a guide:
Billy T.
[email protected]
I definitely want more HP but that will come later.
Based on your CAT ticket isn't that more of towing about 13k if the OBS weighs 7k?
dangerous1
I've grossed 32k in my obs dually, it pulled it but not happily. I gross 14-26k daily and it does fine. No chip in it.
