6.0 oil rail standpipes breaking
webb06
Seneca, MO
Here within the last 2-3 months we have had 6 of the oil rail standpipes break, 4 of which were fresh off the shelf from Ford dealer. Attempted to separate them at the middle connection and the casting on the check valve side literally cracked in half.
2 of them were installed in a truck that our shop did headgaskets on roughly 2 months ago and it came back in this week with a real erratic running condition when revved about 1200 rpm. found the ICP voltage was also really erratic at the same rpm. ended up removing the stand pipes and both of them were broken as well.
just curious if anyone else in the 6.0 repair business is seeing this. our Ford dealer has warrantied all the broken pipes but says we are the only ones reporting anything to them.
seems like a very strange problem to me.
looking for any insight into this problem!
78f100
Bonifay FL
I have had 4 so far broke, none were installed by us. When I removed them they were broke. I did have o e new one broke in the package when I unwrapped it.
webb06
Seneca, MO
glad, but not glad, to hear we aren't the only ones seeing this. were the broken ones you removed the updated style? were they causing any driveability concerns with the truck?
DEEZUZ
NO PUKESTERS
NWI
Have heard of this also, but never had it happen first hand.
Are you wiggling them to separate them upon install? I pull them straight apart and haven't had an issue. Probably install 4 sets a week. Also been having a few injector warranties where we just reseal the pipes rather than install, so they are torqued numerous times
webb06
Seneca, MO
Pull and wiggle, but a casting like that shouldn't just fall apart in my hands or come out of a sealed package already broken.
pdumont01
CT
This is the first time I ever heard of that happening.
AirFishAutomotive
DELAWARE
We have had a set of them come new in the package broken before, have not had any we installed come back
As far as ford and how many people have had the same problem hard to tell if they just make up a random number to tell you, we were supposedly only the 3rd shop in the country to ever have a 6.4 rocker bridge come in and be the wrong thickness causing to much pressure on the valves when torqued down
webb06
Seneca, MO
Called our local international dealer, they've also seen a few broken.
6speedsd
Olive Branch, MS
Sort of makes you think they start dropping material quality in an effort to phase out an older engine. If parts become more and more problematic, people will just stop fixing the thing.
Either that, or the initial huge cash flow Ford made off this engine has subsided, and now they are looking for ways to make their next fortune off of us.
Sent from my SAMSUNG-SM-G900A using Tapatalk
webb06
Seneca, MO
How do you do them? Drop the engine, pull the body or pull the engine? Got 1 to do next week...
Remove the engine mounts, both sides, and lower the engine down. Then you can get both valve covers off relatively easily
Bustedknuckles
What about pulling the body? Thats what we were going to do, or is that way more unnecessary work?
webb06
Seneca, MO
Wasn't sure if it was an ambulance or school bus type body. Never pulled a body on the van type. Seems like that would be more work than removing the engine mounts. Especially if it's full of inside storage cabinets or tools.
Bustedknuckles
Its a passenger van, i think I'm going to pull the body just because it should be interesting. If its too much work ill just pull the motor mounts in the future.
pdumont01
CT
Well not really the whole mount, just the plate between the mount and the block 8 13mm bolts and slide plate out and lower all the way. Gives enough room to get pass side off no problem.
