Ok, today I checked my SCT livewire to pull some codes. The truck is still misfiring only warm and I normally just leave my scanguage hooked up and it never shows any codes. With the sct I got a p0272 and a p0278. These are the first codes I have seen in a while since the scanguage isnt that great at reading it. My FICM tests out at a steady 48.5, cranking, idling, on throttle hard anytime I watch it. I have heard stories about the FICM going bad and still putting out correct voltage. I was leaning towards a HPO problem but now with the codes bouncing around but all in the same bank I am leaning towards FICM or Harness issue.
First number 2 cylinder would drop off on a graph while the motor was misfiring.
Today I check codes and get contribution errors for 4, and 6. So the contribution is bouncing around but all on the same bank. Any help would be appreciated. Im either gonna call ed at FICMrepair or try to find someone locally that will let me swap FICMs and see what happens. Thanks
