6.4 build i did a pretty lot to my 6.4 and thought my dyno numbers were kind of low
jmd2422
hey well then ill shoot for over 600hp aaron is well known so i was just going by his numbers he did say the dyno reads high tho
Jeff@Spartan
Georgia
The results of his dyno testing was good because it showed increases over stock and power below the curve with stock turbos, batmowheel, and Elite 71mm. The peak numbers were not legit though.
jmd2422
well alot of good info guys thanks il upgrade my tunes fix that wastegate leak and have it tuned in better then dyno it and see where im at and maybe have the high side batmo and elites 71 and ill see what happens
jmd2422
new trans is coming thats for sure i happy with the engine build just have to upgrade the turbos a little then a trans for sure
jmd2422
what do you guys reccomend for a trans i was going to do a fully built rudys trans this summer but what have people ben having the best luck with not to go off topic on the thread
jmd2422
ya they sell u a built trans and building it for what u intend to use it for then say your abusing it that makes sense
