- Joined
- Oct 3, 2012
- Messages
- 11,854
- Reaction score
- 30
so you are on stock nozzles now and the truck falls on its face? I still would monitor rail pressure.
How are you locking OD out?You need more air... my s467.7 pulls hard to 100+ stock fuel with very conservative tuning... Very little smoke even towing 5-8k on a daily basis, it will haze constantly going down the highway at 65-70 if i don't lock overdrive out but that's more the 3.55 gearing i have. Small 300 housing run out of air very quickly where the 400 series move the power up a little higher breathe better up top to sacrifice a little low end.
I promise the 366 SX-E isn't running out of air on stock fuel.
if he runs GH tuning, you can lock it out with the tow/haul button
So your on stock fuel with a 467 is it laggy I was nervous about going to 4 frame
Interesting. I don't think my tyrant tunes have that feature.Exactly, tow haul locks it out, and it won't shift into OD until 70mph. So if i'm towing heavy 10k plus i just roll down the highway at 60 or 80 there isn't an inbetween with 3.55's unless i lock out od then i can do 65-70 but the rpms are similar to a 450 with 4.88's and you're running 2500 rpm down the highway
That's one of the things I don't care for in our 6.4 with 3.55s and 35s. When loaded, I run it in tow/haul at all times so that I'm not constantly lugging it. Truck runs awesome at 80+, but on the 2 lanes at 60-70 I have to work the throttle pretty hard to stay on top of it.
It's got a little lag to it still but again i have very conservative tuning from gear head, and have the same amount of smoke down low as i had with stock compounds, and more low boost fueling will help the turbo spool quicker but i don't want more smoke, it's on my company truck, lettered up. I tow with it 6-7 days a week 9-10 months out of the year, no issues. on the highway from 1800-2000, i can build 40psi easing into the throttle without causing a downshift from over drive empty with no trailer on stock tires, level ground. 30-60% nozzles and dual fuel and it would spool like stock i'm sure.
That's pretty impressive. Would you mind posting up a video of that for us? It would be cool to see a 467 coming on hard from such a low RPM. Select boost and RPM on the display so we can see the correlation.
Who's kit do you have and is your a standard 467
