NY_Mott
Hey guys and Gals.
Couple questions.
I am in need of a water pump and after searching the web I have come up with limited sources.
Found this one from bullet proof, but not sure if there is a better route to go.
http://www.bulletproofdiesel.com/Bullet_Proof_Diesel_Water_Pump_for_6_4L_Diesel_p/90201051.htm
also found this but I believe this may still be a plastic impeller.
http://holdersdiesel.com/product_info.php?products_id=962
Is there anything else I should replace while getting the job done? Money is tight, but I am sure it would be a good idea to do thermostats, Right?
Also will need to replace the radiator and have been looking at the Alradco and mishimoto radiator. I read great things about Alradco but see they are on about a 3 week b/o. As for the Mishimoto I have not really read anything bad and they are ready to ship.
I will be waiting to order the radiator on till the 1st of the month and water pump before then.
Just wonder what you guys think as to which route to go with the water pump and radiator?
Thanks
Couple questions.
Thanks
