6.7 rear bucket seats in
02bigstrokin
Thought maybe some would like to see this done. Amp rack is done behind the seat, front buckets are bolted down, rdy to start working on console. Here's some pics
02bigstrokin
It will only let me post one pic at a time so bear with me
02bigstrokin
I like the front and rear buckets in these trucks. Looks good
Yeah I do too because I never have 5 people in my truck and I don't like slim line subs. I liked my 08 with them but the 6.7's don't have that option for some stupid reason. When I get done they will be heated/cooled and full power so they will be able to to slide forward and recline some.
zporta
That's pretty awesome! Very clean install as well. I use my bench quite frequently tho
02bigstrokin
what did you have to do to make the seats bolt down?
Looks really good i love it[/QUOTE
The factory f250 front seats will actually line up perfect with the bolt holes in the rear believe it or not. On the passenger side the four bolts are already there. On the driver side two of them are and two aren't. The two the aren't if you look on the bottom side of the cab the riv nuts are there they just aren't drilled and tapped like the others. Theres even places in the factory carpet where those bolts should be. So I marked them and drilled through the center of those riv nuts and tapped them the same threads as the others.. Bingo both seats bolted down like ford meant for them to be there. Lol
