02bigstrokin
- Joined
- Aug 28, 2013
- Messages
- 235
- Reaction score
- 0
What are you doing for a console
I like the front and rear buckets in these trucks. Looks good
what did you have to do to make the seats bolt down?
Looks really good i love it[/QUOTE
The factory f250 front seats will actually line up perfect with the bolt holes in the rear believe it or not. On the passenger side the four bolts are already there. On the driver side two of them are and two aren't. The two the aren't if you look on the bottom side of the cab the riv nuts are there they just aren't drilled and tapped like the others. Theres even places in the factory carpet where those bolts should be. So I marked them and drilled through the center of those riv nuts and tapped them the same threads as the others.. Bingo both seats bolted down like ford meant for them to be there. Lol
