6.7 Twin Turbo Setup
Athens, IL
Crank flex sounds made up
You don't think there was some excessive cylinder pressure?
Default15405
Houston, TX
How would adding main studs make the block structurally stronger? Your not adding material to the block. In fact it puts more stress on the block, and distorts the main bores.
I don't have enough experience to go off of so bear with me I'm just picking your brain here. I get that no material is being added but it seems that adding a larger, higher quality stud in every sense would make a bottom end a bit more rigid and at the very least allow the bottom end to handle full load longer before it blows. And I assumed that if they had the engine out of the truck it wouldn't be a big deal to get it align honed with the studs getting rid of the distortion.
PDT1081
Bowling Green, OH
It's a play on words. Studs will make the "bottom end" stronger, but they won't make the "block" stronger.
Studs are needed when bolts are not strong enough, and stretch. This goes for any bolts in the motor. If they are not stretching bolts, the bolts aren't failing. If a bolt (or any part) isn't failing, putting a stronger one in its place isn't going to make a difference.
Wayne
Twin Falls, Idaho
what other force could do such a thing ? the crank sure as hell has nothing to do with that.
:lookaround:
LOL that wasn't it. I think this is something better left to speculation. Odds are somebody will nail it within 10 guesses or less, but I won't be the one to confirm specifically.
Wayne
Twin Falls, Idaho
SDS97-7.3: It's a matter of finger pointing that I simply want to avoid. People seem to be so sensitive these days, and I hate to walk on eggshells, so I choose to avoid that discussion entirely. Too much flinging of poo in this thread anyway. Suffice it to say had we been aware, the problem would have been avoidable when it blew up at dpc and when I was doing the "break in". It's also something unique to this truck that I don't see happening again for Dan, or anyone else for that matter. Rest easy my friend. You're more likely to find John Wayne in a gay bar than see this scenario again.
Jonnydime
The only things in common with this motor and the one at dpc are the source of the engine and maybe tuning. Right?
Bustedknuckles
High drive pressure is usually a result of poor tuning or a serious exhaust restriction whether its the turbos or something blocking exhaust flow. My guess is exhaust restriction as he said its a very odd issue...
packin45
Couldn't have anything to do with that bedside tail pipe could it?
Sent from my iPhone
97stoker350
south central pa
Just thinking out loud but high cylinder pressure puts a lot of strain on the bottom end components. So if the crank isn't flexing and the rods aren't bent that leaves one thing... Rod bearings
