6.7 Twin Turbo Setup
Bustedknuckles
Just thinking out loud but high cylinder pressure puts a lot of strain on the bottom end components. So if the crank isn't flexing and the rods aren't bent that leaves one thing... Rod bearings
Bearing failure as quick as he is seeing almost has to be a oiling issue unless the cylinder pressures where just insane.
Bustedknuckles
Oiling issue, improper machining, improper installation.....
Both those last 2 would have been triple checked by the last 2 builders I'm sure. The CFD motor lasted a lot longer than any of these, obviously not at the same hp level but still! One of the reasons I really want to know the cause....
Athens, IL
Did anyone see the glow plugs......? If glow plugs were blowing out, what do you think....
Dan
Fort McMurray AB Canada
The gtx4202 has a 1.0 a/r housing and the 55 has a 1.32 a/r and a fairly big gate around the small turbo.. another thing I'll throw out there is that blue custom auto truck has put down way bigger numbers than I have with 3" holes in that bed side exhaust.. without rod bearing issue
Breaking Habits
Mapleton, Illinois
And the exhaust is post turbo. Backpressure after the charger does not matter, especially that far down stream
Bustedknuckles
So its a drive pressure issue for sure, not a oiling issue?
97stoker350
south central pa
I wasn't blaming rod bearings for the failure I was thinking that since there was all that pressure that it put a lot of stress on the bearings causing them to fail so quick. Yes I saw the glowplugs and it looked like they were about to go through the hood. I'd like to know what the wrist pins looked like
Bustedknuckles
Intresting....
