60% injectors on stock fuel and turbo
TXlineman83
Austin, TX
So I have my cab being pulled and new studs, gaskets and the works going on. Is now a good time to throw in injectors. If I do so can I maintain enough power to pull my 15k travel trailer or will I be loosing that battle
ncollins64
winchester springs, tn
If I had to guess 60% would be way too much for a stock hpfp to maintain even if you pull pw. And egts would be pretty warm with stock chargers also. Just my .02
B585Ford
WV
That would require cutting back the PW quite a bit to maintain RP. My best guess is cruising EGTs would be slightly lower if you could get the tuning down (PW and timing), but I would bet you will lose power running 60%s and a stock, single HPFP. Especially if you do plan to add fuel down the road, if budgets allow, you might want to consider a LP system while the cab is up....it is easier to install cab up (although not a necessity).
Gearhead
stock injectors with just airflow upgrades would be enough fuel to waste a stock trans so personally I'd keep stock nozzles and focus on quality airflow.
