nasty6.6
Ok guys my 7.3 has an issue when idling for longer then 5 to 10 minutes it begins to miss and then shuts off, when you go to restart it just cranks but if i bleed the fuel system at the filter housing under the hood and crank it will start right up and run. As long as i run the truck highway or in town its fine but if i leave it running for any length of time it dies and cycle restarts from beginning.
it isnt consistent and sounds like i'm getting air in the fuel system. Has anyone else had similar issues?
truck is mostly stock you could say just light bolt ons like 38r, intake, exhaust, gauges, all the regular mess BUT no tuner as of now.
