That wheel sucked azz on my truck too, it was an immediate difference when I put the stock wheel back. It was nice at WOT but this isn't a puller so...Who in here is crazy about billet wheels in 38r? Raise your hands!
I have one, my hand is down.
Same results here, one of the only mods I regretted and went back onJust swapped back to the stock wheel. Much better bottom end power. Very noticeable power increase when towing.
On a side not, I have a WW2 for sale! Anyone???
it smokey pulling my rzr around on a 16' trailer
No I didn't, still stock injectorsI believe since our trucks are setup similar we had similar results. Im gonna try some GH tunes with my 250/200s before I ditch it for the stocker.
Did you ever try the billet wheel with your 238/80s?
I do have 238/80s now, but I put the stock 38r wheel back before I got the injectors. I sold that wheel shortly after I removed itI thought you had stepped them up?
ahhh, whitey has 4.10s on near stock tires.. biggest i have ever ran on her where 285/75/16sIve got metric shti tons of fuel its just not a good fit for me for some reason. I don't know if its the 35s and the 3.73 gears. It gets hot. I need to do some other stuff to it before I go back to the stocker. Hell i may try the billet version of the cast wheel. Mines the 11blade single plane wheel as well.
I'm on X codes and stock block out back, I think I want to go back up with itGot ya...i was gonna try it with 33s and stock suspension. I took the rear apart first. 3.5" pmf block and 4 leaf rear sd springs (3k lb rating), put the tires back on and its sitting level :doh: either my 6" lift settled a lot or this thing is gonna sit high af...
