whitemomba
First off thanks in advance for everyones help. This post may be long winded so I apologize but please try to bear with me. Alright so I've been having some cold start troubles with my 2000 F250 7.3 with 247xxx miles. If the truck sits for an extended period of time (8 hours or so) it will not start unless it has been hooked up to the block heater for at least 30 minutes. 30 minutes on the block heater and the truck starts but blows out a good amount of white smoke for a couple of minutes then the smoke goes away. If it is hooked up for a couple hours or so there is no smoke at start up. If the truck is not plugged in it will crank and crank and crank and after about 10 seconds of cranking I will get white smoke out of the tailpipe (which I'm assuming means that I am getting fuel???) but no start. This has been going on for only about a month or two so I haven't had the chance to see if it will start when it is warm outside but it was around 45 one morning and still it wouldn't start until I hooked it up to the block heater. As soon as the truck starts there is no problem and it doesn't seem like it is missing on any cylinders. It does seem like it is lacking a little power once I get it started but I try not to give it much throttle until the temp gauge at least moves off the cold mark. Once I drive it for about a mile or two it runs like a scalded dog. Before anyone asks I do have a chip on the truck and I have reset the truck to the stock tune before starting cold and still nothing. Haven't actually taken the chip out of the truck yet because I'm almost positive this has nothing to do with my problem.
So heres a list of the things that I have either replaced within the last year or checked:
Replaced within the last year:
Glow plug relay (upgraded to the stancor 3 weeks ago hoping this would be the problem) I have battery + voltage to the always positive large terminal and when key is cycled I get the same voltage to the other large terminal
Valve cover gaskets and UVC wiring harness 6-8 months ago. When I did this I pulled all glow plugs thinking they would be bad but all of them ohmed out at 0.5 ohms so I did not not replace any of them.
Two new batteries and new alternator 3 weeks ago. One battery had a bad cell and the alternator had a bad diode so the batteries were being drained over night. New batteries check out at 12.5-12.7 volts in the morning and while cranking hold 10.5-11 volts.
New MAP sensor about 2 months ago. Broke the last one on accident (don't ask me how)
New Cam Sensor installed by Ford under recall close to a year ago.
New fuel filter, the last one only had 4k miles on it but I put a new one in to rule that out of the equation.
Checked:
Oil pressure (ICP) checked from oil rail plug on passenger side head when cranking cold and no start jumps straight to 600 then climbs up to 2200-2500 after about 5 to 10 seconds of cranking.
Unplugged ICP and EOT sensors individually and no start when individually unplugged or both unplugged at same time.
Contribution test and injector buzz test done probably 9 months ago and both passed with flying colors. Haven't been able to do another one yet because my mechanic is about two weeks out. I plan on getting another one done by the end of next week or as soon as he can get to me.
Pulled a code for exhaust back pressure sensor malfunction today but this shouldn't keep the truck from starting when cold right??? It also had codes for EOT and ICP sensor but I'm guessing that was just from when I unplugged the sensors and tried to start it. Cleared all the codes and the only one that came back so far was the EBPS malfunction.
This truck is really starting to piss me off and I can't figure this one out and I don't know why plugging it in is helping it start. I don't have a scan tool so I haven't been able to check IPR duty cycle yet but if that was giving me problems the truck would run rough cold or hot wouldn't it? I've thought about worn poppet valves in the injectors but it passed a buzz test 9 months ago so I would think that I'd have some signs before it gets to the point where it won't start or is that just wishful thinking? If y'all think injectors please give me any tips you have on making trucks "accidentally" explode...you know for insurance purposes. Thanks for all the help.
Checked:
