7.3L Dies Randomly
ToMang07
Mainah!
Weird.... my truck did that this morning. Got the "ns" on the Hydra, and it wouldn't start.
Shut the truck off, removed the key, and tried again ,and it worked.
dsberman94
Pennsylvania
I think your wiring for the wif sensor or the fuel bowl heater might be shorting out. Check the PCM/fuel bowl heater fuse as well.
Black 02
Woodland, WA
Well, after trying to figure out why the truck wouldn't start, I decided to pull out the Hydra chip. Truck fired right up. Plugged the chip back in and it wouldn't start.
rusty1161
Whittier, CA
Went to start the truck again and the thing was dead. Check engine and wait to start light stayed on continuously. The hydra said "nS" now.
I wiggled the relays and nothing seemed to happen. I checked and found fuse #12 (20 amp) was blown. It's supposed to be the cigar lighter/OBD II. I am going to go get one now.
Not trying to be a smart azz, but "NS" is no start. It's not clear if the chip works in other settings?
Rusty
Black 02
Woodland, WA
Rusty
The chip won't switch out of nS. Then, I finally got it to switch to 00 and the same issue occurs. The check engine and wait to start light stays on and the fuel pump won't run.
Black 02
Woodland, WA
The hydra or the connection is not happy
Yeah, the hydra only switches between "00" and "nS". Even on "00", the fuel pump is dead and the gauges lights won't go off (WTS and Check Engine).
There isn't any copper showing on the PCM contacts, but I've ran a tuner for 4 years without issue. I'm guessing it's the Hydra. I'll call ******** again tomorrow.
Dude, it sucks the bumpy road you've been on with this. Good luck!
Wouldnt it be nice to have some turnkey reliability if even just for a while?
mandkole
Northwest
^^ no doubt.. what a struggle.
Do you still have the chip? At least that would confirm that the PCM side of the connector board is ok.
Black 02
Woodland, WA
I just threw my old DP Tuner in the truck and it fired right up. People harp on DP sometimes, but it still works in my truck.... :thumbsup:
Very odd. I'll make some calls tomorrow.
On a side note, anyone change the IPR on terminator twins? I don't want to have to pull the intake and intercooler pipes off to change it. Can you just remove the IPR block???
dsberman94
Pennsylvania
There's been some dead hydras out of the box that I've read about. I'm sure they'll get you taken care of. Glad it was something simple though.
Black 02
Woodland, WA
With my luck, it doesn't surprise me. I bought the chip from Irate, but ******** tuned it. Matt at Irate is working on it for me. I just want to get my truck on the road. It's running with the stock PCM, but it idles like crap and gets really warm really quick, so I'm not driving it until it gets fixed.
Jomax
Arizona
I've been hearing about quite a few hydras.... If this is the case of the chips not being up to par with reliability. I don't care for one
dsberman94
Pennsylvania
Plenty of people have them and you rarely hear of issues. I'm going on 2 years and I'm constantly changing tunes on it, literally every day, and I've never had an issue with the chip itself. The PO of this truck even took off a little too much on the electrical connector and I've never had an issue. Everything has a percentage that doesn't work after manufacturing. Even the $70k trucks some guys on here drive and have issue with within the week. A bad $300 chip would be the least of my concern tbh. Call them up, send it back, and get a new one.
Black 02
Woodland, WA
I agree with you. That being said, my truck is not a street queen. I haul firewood, go hunting, and play in the snow out in the woods where sometimes cell service could be 30 miles away. I didn't spend $20k on mods to have to worry if the chip was going to crap out and leave me totally stranded.
I'm supposed to be getting another chip soon. After I run it awhile, I'll report back.
Black 02
Woodland, WA
Got my new hydra yesterday. Put it in and everything seems fine so far. Put about 50 miles on it so far. I also put a new IPR in it as well just to be sure.
The only issue I had and it did it a couple times.... It used to have a subtle miss when in park revved up above 2000 RPMs. Last night, after it was warmed up, I held it up to almost 3000 RPMs for a few seconds. As soon as I let off, it died. Drove about 5 miles and did it again. Put in park, revved it up, held it at like 2700 RPM and let off. Soon as I let off, it died.
Maybe my ICP connector needs changed too. The old ICP leaked and I put a new one of those on too. Didn't change the connector though. I need to data log it and see what is going on.
