Absolute Performance 6.0 Delta kit and Coolant Filter setup
Jtreece
Kansas
Anyone still running a delta kit? I see crazy deltas after EVERYTHING is done to this motor. this is my last resort.. hopefully
Nope. most people threw them in the trash-myself included. Skip it and find the root cause of your issue.
05wh250
hendersonville, nc
I still run mine but I'm too lazy to take it off. It's not an end all solution. I've had a problem for awhile with temps, swapped my fan clutch for a new one and seemed to fix it. With the old fan clutch you could count the fan blades it turned so slow at idle. The new one you can hear with the hood closed.
05wh250
hendersonville, nc
It did better than the original Delta kit. The original came with a 3/8 hose that went back to the Degas bottle. Not sure how.much it helps but with the ported manifold I don't have much of an option.
