Airbag light code 19
Belswick67
I have recently noticed that I’ve been getting a light on the dash that appears to be the airbag light. After brief research i have found that it is flashing a code of 19. It sometimes goes without turning on at all, sometimes it stays on, sometimes it flashes then turns right back off while driving.... and other times I’m lucky to see it. I’ve read that it means RCM memory is full. I was in an accident about a year ago BUT had no airbags deploy because i was the hammer and a van was the nail. (Lol someone pulled out in front of me) so what should i start looking at?
I’ve had some people say clock-spring but my horn and cruise, everything works as it should at ALL times. Plus my steering wheel lights never dim when turning the wheel, etc. where would you guys start looking to pinpoint this issue?
Thanks in advance fellas!
Mesa, AZ
If the code says the rcm is full, the rock needs replaced. Even if the air bags do not deploy, it may still store a crash event, in which case it will need replaced
