Rmartin-97
I wouldn't put a lot of faith in a compression test like you did. You need to use a actual compression tester on all cylinders. I'm not sure as I don't have the same scanner as you but I can't figure out how it can do a compression test. It must be some sort of a contribution test and a bad injector would cause it to read wrong.
Harbor freight has a decent diesel compression tester.
Oh ok.
