Another leaking Radiator
F150orelse
Ok I’m done, second mishimoto leaks in less than 10k miles! Just ordered csf primary and secondary radiators. Hope this radiator will at least last 5 years
i would just do OEM. There is a reason they do plastic end tanks...
+1.
Please go on about the plastic tanks though
Flex is what kills these rads. Rigid aluminum have no give-hence the short lifespan. Those plastic end tanks flex a lot more than you think, they also expand/contract at a different rate than aluminum.
DEEZUZ
NO PUKESTERS
NWI
10-4. Makes perfect sense. I do have an all aluminum rad in my IROC but that thing doesn't even build all that much cooling system psi
Jomax
Arizona
On a replacement OEM for the last 60K miles....love it.
Lol did it had 50hp? Lol
In all seriousness. I know people complain about radiators but the OEM rad on my 2015 lasted till 125k miles when I traded it in.. zero issues.
08Monster
The new style mishis have plenty of flex. They have the rubber top isolators like stock, but the actual 1in post that goes through the isolator is now rubber as well.
Sent from my Moto Z (2) using Tapatalk
HeavyAssault
Middle, VA
Not 50hp, BUT OEM saved me a ton of $$$$ over that Misho crap.
I found the original one had a leak while conducting an inspection. Just enough of a leak to know it was leaking. As I said that was over 60k ago, 122k on the truck now running everyday, just back from a 2,000 mile run for vacation (and not the only one since the replacement) truck just asks for more.
NMSVT
NM
I'm gonna have to just buy a damn stock radiator. My mishimoto crapper has leaked for awhile now! No time to swap and to do warranty is a PIA. I'll guess I'll go back to stock. Send it in and sell it hearing even the replacements leak.
F150orelse
Yep better off going with Oem.
Arconalloy
Warner Robins, GA
I considered the mishi as Well when my OE cracked, until I got on here and did a little research that is haha. Ended up with another OEM rad since my factory one went to 114k if i get that out of this new one ill be happy
