Anti gel test
jimdawg185
The problem with testing anti gel properties in your truck is the issues that it causes in your truck. You can just mix it up and set it outside as well. But that only gives one dynamic. You can also use the freezer, but that probably won't go near enough to the gel point of winter #2.
jimdawg185
Also, it is important to remember that anti gel treatments themselves can get quite thick. It is mixing them with the diesel that completes the chemistry. Anti gel basically does one thing, it separates the wax crystals from each other when they start to form in the fuel.
04stroker
Sarasota-Bradenton, Florida
I personally do not like power service I have had it in several trucks that still gelled when it got real cold mainly -10 and below. Had 2 dmaxes and a 6.0 do it with power service.
ToMang07
Mainah!
I've used Power Service (White Bottle) in temps as low as -30*F (before wind chill) and never (knocks on wood) had any gelling issues. Sure....truck didn't want to start and bitched for a couple minutes, but never gelled up. I do over-dose it a little bit tho, and use TW3 2-stroke oil as well.
SDS97_7.3
Finksburg, Maryland
It seems to be more of a prevalent issue with trucks that have fuel filters on the frame rail
ToMang07
Mainah!
I only have 1 on the frame, but still....no issues.
I've noticed a lot of the people that have issues live in more southern states, and although I have no proof, my theory is they live in an area with either poorly mixed winter fuel, or still have summer fuel in the tank.
SDS97_7.3
Finksburg, Maryland
Over on CompD there were quite a few guys who have had issues with Power Service and gelling. Majority lived in cold northern states
ToMang07
Mainah!
And if that's the case, maybe I'm just lucky.
Of course, if you knew me better, you'd KNOW that wasn't the case, LOL
jimdawg185
Its no secret what keeps fuel from gelling. You will see companies that can make a good product have issues pop up when they are not ISO 9001 compliant. Its a PITA to keep the ISO standards, but it pays off in consistency. Some of our products are checked 30 times from the base oil entering til the final product leaves. We do it for the 100 million dollar turbines our oil goes into. But it benefits all our customers from the 10 gig power gen plants to the guy with a Sthil weed whacker.
psduser1
on the road
Difference between Dorman and Motorcraft
Quality control
Atsah
Maine
You didn't get lucky Tom, I have used Power Service up here since 2005 and never gelled trucks, tractors, skidders ever.. I give it a good dose of it and it works for me..
morepower02
MN
I've had powerservice gel in blended fuel a couple of times and I dump the 100 gallon bottle in my 26 gallon tank. -20's air temp with a 6.0 both times. Never a issue with 7.3 or 6.6 duramax.
Atsah
Maine
Two 6.0's and one 7.3 for me.. I plowed a lot with all three.. I also added motorcraft performance improver to it, maybe that has something to do with it.. :shrug:
morepower02
MN
Maybe. I think my issues were with small town stations that said blended to a certain temp but were not close. I try to stick with truck stops here in the winter and haven't had a issue. I still dump the 32 ounce bottle in every tank. Sure runs smoother.
jimdawg185
Well, I'm glad not everyone has had issues with PS. However, no one has ever had issues with Full Torque, or BTU+. I have a dozen ice road truckers that use it in Alaska at -40 or colder. And not only did it not gel, it helped their engines run smoother. Let me see If I can upload some info.
jimdawg185
