PowerStroke Connection 2
Manifolds
Correct.
Correct.
Elite is supposed to test again when they get some time. They already have the Godzilla manifolds there to try. I guess they can also try the ones that failed on Mikes truck or I have the new ones at the coater right now too. I'm sending out some of the new ones next week to a variety of shops.
I am thinking of putting my steed speeds on this weekend with the 2" uppipes from Elite. I am going to start right away on Friday after work and finish up Saturday morning. Dyno before and after. Dyno runs with no wastegate and stock turbos.
If dyno my truck and it makes 90 hp and 250 ft/lbs more I will have people turning in their grave. I will belive it when I see it.
I have an idea... Me and Mikey will be taking his out soon to change to the 6.0 style. I could put them on my single cab. I only have the DPF/CAT deleted so far.
lol...i see what you did there . :walkin:
I am going to do it starting Friday night. I will keep everyone posted as to what we come up with. Dyno sheets to compare as well.
Be sure to do the dyno tests rolling into the throttle not brake spooling the turbo. What tuning are you using? If you have Innovative be sure to use the dyno Trans file. If you have h&s with Mcc I can get you the same thing
Any chance you and this Mikey guy can dyno before and after his 6.0 manifold change as well as on said single cab? Pretty please sweet heart? lol
