Backdating rear brakes?
AllanB
Mississippi
I need to backdate my rear brakes on my 08 to an 04 so that I can run an 18" rim on my 08. Just lucky enough I still own an 04 that has the original brake calipers on it and were for an 18" rim. It is a 4x4 and my 08 is a 2wd. Any pro's or con's to this that you guys might know of?
Newark, DE
whats the difference to want to run 18s? back spacing? just wondering becasue thought alot of 08s the smallest you could get was 18s
AllanB
Mississippi
It is a 2wd and I am going to get some DOT slicks for the rear. Can't gettem in 20" , a 18" is as small of a rim as will fit them.
Any SD wheel 17in and up should fit a 08 truck.
You might be right. To tell the truth I haven't even tried. Someone told me that you had to backdate the calipers to run 18" on my 08. I will put a 18" on it in the morning and find out. Guess I could have tried that first. Thanks
91turbogsx
Gardner MA
I was just talking to a guy today who has OEM 17's on his 2012 (ordered it that way.) I always thought 18's were the smallest you could go on '08+ but I learned otherwise apparently.
co04cobra
WV
Been 17in since 05. I dont think you will have any problems.
blk350on20s
You only need to backdate for 16s. Theres a lot to it. A lot more than i thought. Kind has done a writeup on it somewhere. Or atleast a partslist
