sidwaz
What are the best injectors to use with PMR's. I have a gt38r and a dp tuner f6. Would like to make 400-450 rwhp. I only want to but injectors once. I was tinking about Swamps 200/30 or maybe Casserly 238's. Suggestions?
Every time I see one of these threads about "what injectors are best" for whatever unstated purpose - I want to answer 400/400s.
What are your plans? Goals? Usage? Requirements? Give us something. If you want us to tell you what injectors will allow your PMR motor to live forever - the correct answer is NONE - not even stock. If you understand the risk of modifications, understand that you need to get some tuning for the new sticks that keeps cylinder pressures in check, etc.... then I STILL can't answer your question because I don't know what you want to do with the truck. Stage 1s might be perfect for you - 300/200 hybrids could be where its at. Everything has a level of risk and a level of performance - its a matter of knowing what level of risk is acceptable and what level of performance you wish to achieve.
Jason
Unlimited's 238/80's or 100's. That will get you right there at your power goal.
I was @ 430rwhp (92.2@8200lbs) for 2 yrs with those inj. Still running them today with zero complaints...
Jason
600/600's....Just put those rods outa their misery fast and swift. Then move on to better rods.
