What are some of the best pads and rotors I can get on my 2013 f250. I was looking at ebc pads but can't seem to find the rotors. Truck does some heavy towing every once in a while. Any input is appreciated.
I have EBC pads on mine and they work well, still wish they dusted a little less but they are better than factory. One day i guess ill have to put new rotors on my truck and some different pads as well. I have worked out the pads plenty with loads that were much to heavy for the truck, seemed to hold pretty well.
My HAWK pads hardly dust at all. Might be worth a shot if you wanna try something different.
Good deal man.Just placed a order for Hawk pads and rotors for my wife's edge if I like them Ill get them next for my truck too. Thats good to hear about the low dust though, since auto anything had a 20% off for the pads and rotors together. :thumbup:
i thought they where all the same size?The problem I am running into is the brakes on the 13's and up are larger than the 11-12 trucks and most of what I find is for the 12 and below years.
any idea if the 13+ is a direct fit upgrade for the 11-12s? obviously the caliper rotor and pads would all have to be changed but i would assume that if the axles are the same then the bolt location should still be the same i would think.....
The F-250 and F-350 (SRW & DRW) have 13.66 inch front brakes and 13.39 inch rear brakes. The 2015-2016 F-250 and F-350 have 14.29 inch vented disc brakes on the front and rear axles as an improvement made for these model years.
10-4. thank you sir!Seems there was a thread on it by CMX or someone living in NY...
According to Wiki, it is the 15+
