Best tracbar?
BIG JUICE
Valrico FLA
I need a track bar for my level kit. Whom makes the best one? I was going to get a carli just to keep it all the same brand. But checking out the pmf also. Any input on what's currently good?
Jomax
Arizona
If you have carli products already, I’d personally stick with carli.
NHRMK
I wasn’t a fan of my icon bar, I replaced it with PMFs bar. Couldn’t be happier, only down side is you can’t adjust it on the truck.
BIG JUICE
Valrico FLA
I ordered that ready lift bracket. I am concerned that I can't adjust the center of axle though. Keep reading that only driver side tire will rub radius arm with my level and 37" tires. That leads me to believe the axle ain't centered
DTL
Bakersfield, CA
I've used a number of products from PMF (including their track bar) and the quality of their work is always outstanding.
04cr450
harford county, maryland
Good economical purchase. It will do the job just fine. The bracket is designed center the axle for a 2.5" lift.
Smokun
No two trucks are ever the same. If u measure the thrust angle on most if not all trucks on the lot brand new they will be off. Maybe not enough to bother some but dogtracking down the road annoys my ocd. Must get one that is adjustable and it will not only look better but it will drive better as well.
BIG JUICE
Valrico FLA
Can carli be adjusted on the truck? I'm thinking not. Just has jam nut like pmf. The pure performance one has a fancy end. Any body ran or know of those?
Smokun
If it’s got a jam nut and no adjusting sleeve the rod end will have to be dropped out of the knuckle and spun in to desired measurements reinserted and remeasured.
