Best way to Launch
dseitler
Royal Palm Beach, FL
Turning off the Trac Control does not work at all. I was hoping the SPE locker would disable the ABS and Trac Control. Mine does not. Maybe the 13 is different but I can tell you first hand trying to do a burnout is violent when it de-Fuels and then kicks back in. I was thinking of just removing the fuse on the ABS and see how that works. Possibly tie that into a upfitters switch with a relay.
Powerstroke Cowboy
Montana
But are you turning off the Advanced traction control?? There are two different ones. The traction control and then the Advanced traction control.
bigrpowr
<How I Fly
Administrator
my 13' does great burnouts.
griz700rocket
Cisne, IL
Correct me if I'm wrong but first push turns off trac control, then you press and hold to disable advance trac. Two separate functions.
bigrpowr
<How I Fly
Administrator
yep, hold for 5 seconds or longer. the dash display will tell you when advance trac is off.
Rowdy
Fort Worth,Tx
Yes exactly what he said! You push traction control button once and dash will say traction control disabled. Then you push and HOLD traction control button down for 5 seconds and the dash will say advance trac disabled. If you have the SPE locker relay installed you can lock the rear diff and melt the tires. Without the SPE locker relay you can not lock the rear diff and do a burn out cause it will defuel.
Dzchey21
wyoming
holding the botton should do the trick, i can get my truck to do cookies if i want doing it this way, and its totally stock not even tuned. Unplugging the sensors at the track is a bad idea if you ask me, you will want ABS features to kick in if you wet the track or something.
bigrpowr
<How I Fly
Administrator
agreed. especially in a 2wd .
that being said, i cut a 1.90 leaving very soft the other day with full tire pressure. i think it should cut low 1.7's if i try . and i'm sure the 3:31 hurts it a bit too.
sootboy
Maryland
I get what the other members are advising. Yes in theory holding down the button for traction disables it.
I can tell you I hsve held it down and advance track disabled come on.
The burnout still goes to crap and the truck defuels at speed.
Abs is great but on a track truck its a luxury I can't afford.
I pull the sensor or fuse and life is fine.
Datalogs do not show the problem because I think it is a can bus message from abs requested torque.
I did not come to argue. I am just posting my own experience.
My 2wd 6.7 is very difficult to stage. I am finally getting it I think.
This will be a good thread.
There are 2 other members with some 750ish trucks also.
Maybe they have some insight.
dseitler
I am going to try everyone's advise this afternoon when I can get out of town. I believe I have already done the double deactivation but I want to make sure. I really appreciate everyone's advise. I thought the cookie comment was awesome. I'd like to see someone do that!
2wd-fire
I would think the 3.31 would help.
hopefulHP
Mead Co/ Williston ND
My truck with the advance Trac off will not do a burn out. It de fuels and Pisses me off. 4wd launches are no problem but I want to get them down in 2wd
Sent from my HTC6500LVW using Tapatalk
Rowdy
Fort Worth,Tx
Are you engaging the rear diff lock? If so this could be the problem. At least with my truck it was. I could leave the diff unlocked and do burn outs. Engage the diff lock and it would defuel. Now I have the diff lock relay kit so I can do it with the rear diff locked.
Rowdy
Fort Worth,Tx
Not sure about the 2wd problems but a buddies truck built at Mad Matt's with Carrillo's , push tubes, valve springs, studs, duel fuelers, and MPD 66mm kit will smoke the tires in 2wd and 4wd! He has to baby it off the line to keep it from spinning all 4 tires!
hopefulHP
I've tried both ways. As soon as it breaks the tires loose with the diff locked it cuts power, and with the diff unlocked it will spin them for maybe a second or two then defuel. in 4 wd at 10 psi of boost is where it feels the fastest.
sootboy
Maryland
Yes exactly.
And I have a spool in mine so its just not happy until the abs module is sleeping.
2wd-fire
The 3.31 are helping me at both ends.
Ultimatey I will have to go to 4.10 and 33x16 slicks but I am doing the best I can on a budget for now :jammin:
I ran slicks in my 6.0 33x12.5w with 3.73 gears it was a little scary with anything less than 12 psi in tires
