Blown head gasket????? HELP
THETANK01
May have a blown headgakset(s). Driving from Panama City beach back to New Orleans. Running 75 entire way. Stopped in foley Al for some food and I noticed my truck had puked when I got in the lot. Let it cool off and topped back off to make it home. No issues again. 3 days ago pulling a 25’ goose neck loaded with ab 13k on it truck puked again after about 10 miles under 45mph. When I got home with the load and **** it down I heard bubbling from under the hood. Opened it up and saw what looked like the coolant boiling in the degas bottle. Are these symptoms in line with blown HG? Truck has 222500 miles on it. HS tuned. ******d but not fully blocked off egr. Any info would help.
THETANK01
Oil temp 207-215
Coolant 195-200
Trans 180-195
Egt floating around 700
THETANK01
Never saw any spike in temps. All seemed normal in my opinion.
Petro
Lincoln Nebraska
You could try a new cap, just to rule it out but it's more than likely a head gasket. Good luck, from what I see around here, 6.4's over 200k are on borrowed time for needing a short block.
THETANK01
Put a new cap on it just before this happened
THETANK01
Would them not bring blocked off cause that? Been ******d for about 80k miles.
