Bullet Proofing low mile 6.0 advice please
Navigator
Ashland, WI
Hi, new here but not to Ford diesels. I have a 99 7.3 I bought new in 98 it now serves as our work truck. I had a 06 6.0 that I didn't bulletproof and sold at 99k and I have an 12 6.7 as my current truck.
I just picked up a 06 6.0 KR with less than 7000 miles on it and I want to make it my daily driver, something super dependable, fun to drive and reliable with decent mileage for long road trips.
Something that I don't have to mess with than than routine maintenance.
Here are my tentative plans for it:
ARP Head Studs 250-4202
Ford 6.0 Head Gasket Set 20mm 6C3Z-6051-AA (Yellow Dipstick but 12/27/2005 Build Date?)
Exhaust Manifold Gasket Set MS19311
Intake Gasket Set MIS19311
IPR EGR Delete Kit w/Up Pipe
DC Power 190 AMP HD Alternator
DC Power Big 3 Oxygen Free Copper Cable Kit
Sinister Coolant Filtration System
STC Fitting on the HPOP 4C3Z9B246F
IPR HPOP Extreme Duty Stainless Steel Screen
Blue Spring Upgrade Kit
Edge Insight CTS
Edge 98603 EAS Starter kit w/ EGT Cable for CS and CTS (expandable)
Edge 98607 EAS Pressure Sensor 0-100 PSI
River City Diesel 6.0 Upper Fuel Filter Cap 1/8 NPT
Edge 18302 05-07 Ford 6.0L Dash Pod
Edge 98003 CTS Pod Adapter
SCT X3 Power Flash Custom Tuner for Ford 6.0L w/Unlimited Custom Tunes (Quick Tricks)
New Factory Oil Cooler
Turbo Oil Drain Tube
Updated Turbo Feed Line
FICM sent to ficmrepair.com Ultra/Atlas 40
4C2Z-12A690-AB - Passengers Side Glow Plug Harness
5C3Z-12A690-A - Drivers Side Glow Plug Harness
8 Injector O-Ring Kits
Valve Cover Gasket Set
2 Rocker Carrier Gaskets
Mishimoto MMBCC-UNI-BL Blue Baffled Oil Catch Can
Maryland Performance Up Pipe or MBRP
Exhaust Back Pressure Sensor 5C3Z9J460A
HFCM Water Separator Drain Plug Upgrade 6E7Z-9C082-A
MBRP S6214409 4” Turbo Back Cool Duals
Mishimoto Silicone Hose Kit MMHOSE-F2D-05MBL
Slant 10238 Degas Cap
NUC Ford 6.0 Deluxe Bypass Oil Filtration Kit
Sinister Diesel Ford 6.0L Powerstroke Cold Side Charge Pipe
Riffraff Diesel Billet Compressor Wheel 05-07
BPD Titanium Turbo Bolts
I am undecided on the BPD Billet Water Pump
Magnaflux Heads, Vacuum Check the Valve Seals to the Valve Seats & Machine Heads Flat
Change all fluids, bleed brakes until fluid is clean
Clean Turbo
Flush Coolant with Restore & Restore Plus Fill with 50/50 Distilled Water & ELC coolant concentrate (CAT EC-1 Rated)
Anything I am missing, suggestions ect. would be appreciated.
pedaltheglobe
Real nice. Hard to imagine the story of how an 8 year old truck only accumulated 6k miles. How much did you pay if you dont mind me asking?
morepower02
MN
Besides basic fluids save your money and just drive it. The "bulletproofing" mods in my opinion after owning 3 6 liters are a waste of funds on a good truck.
range91
michigan
Get some gearhead tunes, exhaust, coolant filter, egr delete fresh filters and fluids and drive the SOB
Bigred91
Georgia
Definitely pull the turbo apart. The vgt turbos do not like when they sit for a long time. Clean the unison ring and use some anti seize on it when reassembling
Darkhorse diesel performance
101 northgate industrial drive
Ballground, ga
(678) 454-2277
Monster12valve
Mentor, Ohio
I dont even want to think of the problems your going to have if yours is like mine. Mine is an 06 with 70k, I drive it about 3k a year since I have bought it, and I have replaced... The turbo, the ficm, the hpfp, the brakes and all the u joints. The dealer tells me it's because it sits to much. I made it a point to start driving it more this year.
Navigator
Ashland, WI
I will be upgrading all of those things and driving it 10k or so a year.
Twan
Berthoud, Co
Nice find man. My 06 has treated me very well for the way it got used.
Sounds like a nice build. Should be great for years.
Jbenso127
Centrallll Florida
I dont even want to think of the problems your going to have if yours is like mine. Mine is an 06 with 70k, I drive it about 3k a year since I have bought it, and I have replaced... The turbo, the ficm,the hpfp, the brakes and all the u joints. The dealer tells me it's because it sits to much. I made it a point to start driving it more this year.
Hpfp?
G Racing
Southeast Texas
I would send the ficm to swamps and I would use the egr delete, coolant filter and delta kit from Steve at absolute performance. Really no need for the new turbo bolts. You will get new bolts with the turbo drain gasket kit.
