Bunch of 7.3 parts
JuststrokeIT
Parting out my 99 F350 just don't have time for it anymore. Everything is still on the truck and will be pulled as it sells. All parts are plus shipping unless otherwise mentioned
BTS built 5/13/14 has only 5 miles on it installed and drove home asking $5100 would prefer pickup
6.0 transcooler and all lines and hardware to install 5mi on it-$265
200/80% swamps injectors maybe 8k miles on them-$1300
38R with wastegate 8k miles-$1300
Adrenaline HPOP 8k miles-$450
diesel site HPX line-$100
TS 6 pos chip currently has swamps tunes-$200
3" Plenums-$100
IC pipes $75
Spyder-$100
Spare dash minus air bags and the outer trim pieces and gauge cluster- $125
Regulated return with bowl delete with aeromotive pump and regulator- has pre and post pump filters $850
Brand new GEM module installed just to verify it works D-code-$300
sterling 10.25 with 3:73 gears bought 2 years ago from a guy to keep as a spare has 08 rear cover-$450
305/70/r16 BFGoodrich All-Terrain KO tires installed same time as the transmission and only have 5 miles on them would prefer pickup $1000
JuststrokeIT
PM sent. Cant send the 2nd message until you delete some msgs thou its saying your inbox is full
WILD_PHIL
East TX
Where are you located? I think I remember seeing you're in the south west. I'd be interested in the dash if you're close to Texas. Stock IC pipes?.
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
Diesel23
NWI
Hey , Dang man thought you were out west , if your in Illinois text me maybe interested in dash if I keep my 99 will know hopefully in 2 weeks ,I'm in NWI but travel to northbrook area quite often - thx frank
