Can hpo leak cause smoke ?
06Amarillo
Stc fitting is gone in my truck. I can hear it rattle and j have a hard time with hot starts. My truck smokes as well. Do my question is. Can the hpo leak cause an injector to smoke ?
crcrawford87
Low hpop pressure will cause low power but not smoke, truck will have a lack of fueling not overfueling. I'm betting on a sticking injector
AirFishAutomotive
DELAWARE
How do you hear the Stc fitting rattle, if it was possible to hear it rattle then it would not be connected at all
AirFishAutomotive
DELAWARE
How do you hear the Stc fitting rattle, if it was possible to hear it rattle then it would not be connected at all, bad Stc wouldn't cause smoke, sounds like normal stiction and injector top seal could be blown causing hard hot start
06Amarillo
I can hear it at the back of the motor. If I slowly drive away from a stop sign etc. Also if my truck sits over night it cranks a lot before it will fire for the first time the next day.
