stroker2
First off, i drove home last night and parked it and it had a slight lope to it. Just enough to make me notice it. I just shut it off. This morning comes around and i fire it up. Has a bit stronger lope and it continues as i let it warm up for a minute then i BARELY blip the throttle thinking i could level out the lope but the thing revs to 2k and comes back down and dies. Try and restart it and it doesnt even try and fire. Absolutely nothing. I check a few things with my SCT touch and duty cycle reads .84, FICM voltage at 48.5v, and ICP at 0 psi.
Im thinking my STC fitting decided 70k miles was all it wanted. Do you guys think the same. Do i need the updated STC fitting? Also, if this is the case, is my hpop phukked? Thanks again guys!
P.S.- i have NO codes
