Carli airbag leak?
jaynick1
Texas
Just installed some carli airbags and they seem to leak down pretty good. I know the hose c9nnections are the usual suspects, but for the tapered screw in connectors to the airbags themselves I put thread tape to help seal. Should i not have done this?
Swampfox
TN
Call Carli, they are always more than willing to help with their products. Have you checked all connections with soapy water looking for the leak?
Betarocker
Sea to Sky, BC
I have had issues with push to connect fittings leaking over time. Prefer to use compression fittings. Inflate bags to max and spray all fittings and with soapy water, including filler valve. If not leaks detected, spray the bags.
jaynick1
Texas
Yeah my drivers side is leaking aabout 20 psi every 2-3 hours. I hate those fittings, they have always leaked on every airbag I have owned.
