CCSB Fuel tank swap
CATDiezel
What would prevent me from installing a fuel tank from either a gas 2011-2015 f250 into my short bed?
Or a tank from a long bed f350?
Assuming my def tank is gone.
Trying to avoid a titan or TF.
Thanks.
CATDiezel
26 gallon. Useable is like 23ish most ive ever seen put in past E is 22 on most trucks
ghohouston
Lewisville,Texas
Interesting. Not too sure on the new trucks, but my 02 eclb had a 38 gallon tank. Is that what the new long bed trucks have as well?
8WR_ZJ
Thats what mine is roughly. About 36-38.
Odessa, Tx
If I'm not mistaken it'll fit right in. Strap points are in the same location. Fuel pump is in the same location And the tank goes forward towards the fuel filter I believe. If you have the def tank removed I would see why it wouldn't fit. That's one mod I've been wanting to do.
BIG JUICE
Valrico FLA
I asked the same question earlier, was told won't fit to the front. didn't think about gas tank not having def tank in rear. The mounting straps are in same spot. should work
CATDiezel
If someone could verify depth for sending unit inlet/outlet and location of sending unit I would gladly give it a try.
8WR_ZJ
I can take some pics Saturday with tape measure streched out across the tabk under my truck. i am away from my truck until then.
Jomax
Arizona
I'm in for this too. I don't really want a titan because of how low they hang.
If nobody else responds with a solid answer I'll give it a try when I get time. Been meaning to get rid of the Def tank anyway.
def tank will hold around 6.7 gallon of fuel if you remove it and gut it out and use it as a spare fuel tank... i did that and ran a small fuel pump from it to the filler neck on the fuel tank. filling it is a pita but i only use it when i go on long trips.
