cheap 5.4 coils....
Dzchey21
wyoming
Not to bring back a dead thread... But...
Anyone know how much 5200 lb springs lower vs 6000?
Need to drop about an inch out of my 6.7
bigrpowr
<How I Fly
Administrator
mine were 5200 ..aaron used 4800 ..his was about 1/2" lower than mine.
Jeff@Spartan
Georgia
I thought Aaron had 4400 lb springs? That's what I had and we had the same part # because he gave it to me.
oneturboforme
they dropped the front of my truck 7/16s not much at all rides a lot nicer tho... i will re measure and see if they settled in any seeing i measured as soon as i dropped the jack.. ill let ya know
Jeff@Spartan
Georgia
I bet they end up settling to about a full inch. My 4400lb springs settled to about 2" lower than stock and ended up with the factory rake with the rear block removed. 4800lb probably settle to about 1.5" total.
Dzchey21
wyoming
4800 might be too soft for me. Let me see how the truck looks with my trailer loaded with a crewcab long bed on it and I'll decide from there
StockCar#10
cheyenne,wyoming
How many of youguys are running 5.4 springs that tow a gooseneck? Any height issues with them an no rear blocks? Also what springs do you recommend for a reg. Cab
stroken
This is how my truck sat with the 4400 lb springs and no rear block.
Do you remove any rear springs? or just the block? I think im gonna change the coils I have in now to a 4400 and remove a spring.
Jeff@Spartan
Georgia
I didn't remove any rear springs. My current setup is no rear block and 4800 lb coils. It sits level. That setup you quote sits pretty nose down.
John@Outlaw_Diesel
Pittsboro, IN
Here are a couple photo's of 4800 lb springs and no rear block. This is right after install. I think they will settle a little bit more. They dropped right around 1.5" compared to the factory springs.
Pizza pig
MD
looks like a slightly lower f250. Looks great, still looks raked to the rear in those pictures. If it settles some more it should be just perfectly level.
Definitely going with the 4800 spring over the 4400.
