Choppy idle randomly
lariat 7.3
Did it again today. Stumbled gauges kinda flickered And check engine light and wait to start illuminated. Felt like it died, switched to N and it fired back up. OD switch doesn't work could I know the wire shorts could that cause this
Sent from my SM-G935V using Tapatalk
Mesa, AZ
The icp sensor circuit low code is most likely your issue.check for oil in the icp connector. If there is oil there, change the pigtail as well, cleaning it doesnt work 90% of the time.
lariat 7.3
Voltage has always been 13.5+. Oil in Connector. Been driving all day without it connected been good so far
Magnum PD
VA
If you get another one you better get a name brand one. It’ll be like $125 or so. RiffRaff sells them.
