cknox121's slow build
68 on the mini maxx is fine. just keep it below 70 unless you are using an analog gauge because the factory senor maxxes out at 72
Cknox121
Augusta GA
Drake isn't using the mini max. Just didn't want to float a valve
Sent from my cracked iPhone using Tapatalk
Erikclaw
Central CA
float a valve or have a valve hit the piston. Can you float valves in a diesel like you can in a gasser?
97stoker350
south central pa
It's my understanding that floating a valve is due to too much pressure and valve piston contact can result from valve float OR not enough clearance to begin with. Valve float can be controlled via the gates and boost. However if there's not enough clearance from the get go you will have contact. Contact can even come from rpm but that is a side effect from not having enough spring pressure to return the valve fast enough
Motostroker
We won't float a valve. I have way to many guages hanging off the wipers and IDS in cab to monitor everything. Summit needs to hurry up with the fittings and we will be roasting some grapplers
Cknox121
Augusta GA
Iirc that's what's causes valve/piston contact. See below.
That's the plan! Thanks
Lol I bet people are like wtf when they see it. Maybe that's way all videos are at night lol.
FWIW - the shop that did my motor work installed Pistons and then decked them flat with the heads, or something like that, to prevent piston/valve contact. I was going to have them cut but I didn't think I was going this high of a hp build. Oh well.
10-4, i though i saw somewhere that it was H&S tuning, my bad
you can float the exhaust valves by having way to much ebp which pushes the valve open and doesnt let it seat even if there is no force from the pushrod (hydraulic lifters dont help)
excessive rpms can cause intake valves to have piston contact because they dont have a chance to seat properly before the next revolution comes around
