I guess you didn't read the comments after the video. Just because you can doesn't mean its safe to do. There isn't a router manufacturer or bit maker out there that would recommend using a router on any metal. The bit can shatter causing severe bodily injury.
Routers usually run at 15,000 to 20,000 rpm. Metal die grinders run at about 3,000 rpm using speed rated stones or carbide bits. Lathes run maybe 150-300rpm. So when the wood rated bit shatters, you're in trouble.
Just because you see some idiot do it on the internet doesn't mean its safe or results in a quality job.
Even the idiots in the video said "Be careful", they knew it was dangerous. And it seemed like they used a speed reducing supply to slow the router down.
