dsberman94
But a router bit meant to cut wood at 20k rpm is gonna become shrapnel if used to vigorously or rough on anything but wood. Including a nail in a piece of wood sometimes. Guys in video are lucky IMO.
I guess you didn't read the comments after the video. Just because you can doesn't mean its safe to do. There isn't a router manufacturer or bit maker out there that would recommend using a router on any metal. The bit can shatter causing severe bodily injury.
Routers usually run at 15,000 to 20,000 rpm. Metal die grinders run at about 3,000 rpm using speed rated stones or carbide bits. Lathes run maybe 150-300rpm. So when the wood rated bit shatters, you're in trouble.
Just because you see some idiot do it on the internet doesn't mean its safe or results in a quality job.
Even the idiots in the video said "Be careful", they knew it was dangerous. And it seemed like they used a speed reducing supply to slow the router down.
Die grinders run 20,000 without load
typical of you Davey. no real experience. I would love to see you use a grinding stone on aluminum.
maybe with a compression fitting in there somehow as well
Many people use wood bits and blades on aluminum and they are professionals that know what they are doing. The original question has more to do with de-lipping the piston's on an assembled short block
Well ill put in my 0.02$ on the router thing. I have actually done a lot of routing on aluminum via a wood router. But sure didnt use a wood bit!! I used whats called an AlumaKut carbide burr specifically designed for aluminum. What was really nice is i could make plexiglass(or whatever) stencils for patterns and then put a guide on the router to follow the outline. It was pretty slick. WD40 or equiv is deffinately a necessity. It leaves a pretty descent finish. I actually used the router method on some of the cutting out of the front cover for my P-pump conversion. But on the topic of delipping, i know nothing about it, but i want to learn for the motor im building. Anybody have a pic of a stock piston and a delipped one for comparison??
And I see you stated you used a metal blade to work the alumium. The Bozos in the video used a wood rabbet bit about 2" in diameter. That's dangerous.
A router is nothing more than a high RPM hand held spindle. With proper bit choice you could most certainly cut aluminum with one. There are many people making CNC machines using routers as spindles to cut both wood and soft metals such as aluminum. If someone were to devise a solid method of chip control it wouldn't totally be out of the realm of possibility.... but not something I would recommend. I would not be shocked if it was found out that this was done by someone already. I know this is not the first time it has been discussed.
