Deranged rebuild, the next chapter
Cutting-Edge Diesel
Newkirk, OK
no need for PMs.... this is from the site
This Liquid/Air intercooler is built for massive boost. Special innovations in the core and end tanks allow it to operate at continuous pressure of up to 150 PSI.
Each of these intercoolers is pressure tested to hold 170 PSI for 30 minutes at the end of production. The trade off is that a slightly thicker metal is used in the intercooler, reducing efficiency.
This is an enormous water to air intercooler.
The proportions are somewhat ridiculous, please make sure it will fit before ordering. If you have the room, there's nothing better.
The height, its smallest dimension, is nine inches. This intercooler is more than five times larger than our smallest core. Recommended for up to two thousand horsepower.
100% Lightweight aluminum, No Epoxy Used In Core
Recommended for up to 2500 CFM / 2000 HP
Pressure Drop: Less than 0.5 PSI. This is not a typo! Liquid/Air Intercoolers have incredibly low pressure drop.
Inlet: 4" Outlet: 4"
Core Size: 9.5"x9"x9" (Endtanks add to length)
Maximum water/air pressure: 150 PSI
This intercooler has the inlet and outlet on the SAME SIDE.
Note: The water inlet and outlet on most water/air intercoolers are BPT threads. BPT fittings are difficult to find in the United States, so ours all come with NPT
threads.
http://www.frozenboost.com/product_...d=948&osCsid=fd92c727170f58b4e09a4ddfcfdb8b71
JMart
DFW
Thats pretty sweet. Glad to see some progress going on here.
STROKIN N STYLE
GOM via NC
Why would the Rudy's event be to far if your planning on going to Phoenix? About the same distance... good luck with the progression on the truck!
Redneck6.0L
Great work. Can't wait to see her run. Tim had hrs and hrs of quailty time in the truck, always a pleasure to see it out and look forward to seeing her run again
vanderchevy18
Benton, Ks.
Hey Matt, you ought to bring it by here and make a few test passes before a diesel event! Maybe you'll beat me this time! LOLLOLLOL
Cutting-Edge Diesel
Newkirk, OK
Naw, he is a busy man and he is busy for a reason! We have had him build our performance gas motors like our cj428 and he does great work! And he only has 3 fingers on his left hand so he is short some tools LOL
