diesel mustang..the rattlesnake
imelmo
I like everything except the hood stack. I think I'd do a fender exit.
mandkole
Northwest
^^^WHS Im a mustang guy and I love it, but the exhaust had the easy button pushed. Im feeling pro 5.0-style side fender exit... It would need to be behind the tire to not let smoke block the beams at the track.
taterthedog
Canada
I like the hood stack. I'd say space for anything different would be pretty tight on a mustang.
Dzchey21
wyoming
Damn man this thing is bad ass, I love fox boddies. I have always wanted to do a 6.4 in one for a drag truck
Looks like it gets down pretty good keep it up!!!
Sully
I had plans to do rear exit factory style tail pipes, actually have them and may still but I wanted it to make a statement. there's no way I'm cutting a hole in the fender.I can fix the hood and repaint it in no time being fiberglass and only one color.start to finish in the booth,the paint took 22 hours.with 100 hours in body work before that easily.I will say one thing, when you spend 3 years building a car like this, you might push the easy button a time or 2.
imelmo
DOn't you have a truck laying around that you can pull one out of? :D
doesnt matter, if it makes a legit 500 to the wheels its going to be fast
That'd be mid to low 11's depending on launch.
WILD_PHIL
East TX
Super bad A$$. I was kind of hoping for a normal car getting this conversion just so I could ask more questions. This is awesome. I have always loved the thought of a 6.0 Mustang. I would get simple badges made that said 6.0, just like the 5.0 badges. Awesome build. I plan on reading it for the rest of the day st work. LOL
Let him bear the palm who has won it
weazel
Elkview WV
That thing is awesome, you should put a gooseneck hitch in the trunk, then you could really *** with people
Sent from in a ditch up side down and on fire with the wheels still spinning
Sully
We determined the lack of a maf sensor was causing the pcm to go into emission safe mode and cut fuel.not wanting to pay an exorbitant price for the bung to mount one in 4 inch tube I made one..Just gotta weld it up tonight.hope this fixes the issue.
TheReelMuhcoy
New Jersey
That is awesome! You'rs looks like mine too! only a lot cleaner!, I notched the pipe, and set a piece of 3/8" flat stock in.
Great work man! :thumbup:
Sully
Well I got rid of the maf code but didn't fix the defueling issue.I have codes for the fan circuit,egr, and speed sensor.I'm now thinking the lack of an abs module and speed sensors is causing the issue.is there any way to turn off the abs? The other option is to try flashing the pcm to an econoline program.the e series uses the oss to calculate speed and didn't use a vss in the rearend.but,i have no idea if the pcm or harness is compatible...last resort I'm looking at minimum adding the module and a rear speed sensor which I have none of...Might be able to put a tone wheel on the driveshaft yoke.
