Doing rocker arms.. Anything else worth doing while I'm there?
Six_Sloww
Southeast MI
The rockers on my truck are making more noise then ever and I figured I've gambled long enough..
So far I've got rockers, injector lines and ported fuel rails on the list
Are pushrods or valve springs worth doing on a truck that is only ever going as far as stock fuel takes it?
webb06
Seneca, MO
Springs aren't do able with the head on. Unless you buy an expensive tool, but I'm not sure who even makes one
Six_Sloww
Southeast MI
I just remembered I don't want to have to pull my glow plugs out anyway.. They work fine and the truck has high miles.
SEABEE08FX4
Montgomery TX
Actually it is, just turn the motor over by hand until the cylinder your working on is at TDC. Then use a spring compressor and swap them out one by one and repeat on the next cylinder. I'd also suggest ditching the rails and going with the valvetrain upgrade.
webb06
Seneca, MO
I said it was....but you have to buy the tool. Which for most people isn't feasible if they're using it once.
Unless there's some other tool that you use?
SEABEE08FX4
Montgomery TX
Just a standard spring compressor, but even with the head off you need a spring compressor. Whether it does 4 at once like the Swamps one or just a generic one at a time style you'll need one or the other to do it. Just wanted to make sure people didn't think it can't be done with the heads on.
webb06
Seneca, MO
Post a pic of what you use. Mine has to wrap around the back side, piston side, of the head and hold the valve while the spring is compressed
SEABEE08FX4
Montgomery TX
Either one like this, or the tork tool one we have thats cummins specific.
