- Joined
- Oct 3, 2012
- Messages
- 11,849
- Reaction score
- 36
you are going to need to add a pump and turbos regardless. i would add air at this point as it will make it run cleaner, cooler and make a marginal increase in power.
I know my pumps limited either way, hell I'm really not racing it. I've just seen egts rise & was like WFT but didn't think of how hot fuel running on these things.
Once ready I'd like to address both air/fuel together is my hopes..
Why halfass it? WTF us so hard about that? WTF does your simpleton ass not get about that?You my friend have a thick skull. If a tune fixes the problem FOR NOW then why not do that until turbos can be bought??!!
The point is what's the point in having the nozzles if they are dialed way back? Just as you're saying smaller PW will cure it so will more air and not only that it will make more sense given the nozzles are there. Build upon what you have don't go backwards. If dialing the PW back to stock like tuning is the solution then pull the nozzles off because you're treading water.
My point being its a bandaid ( halfass ) fix and defeats the purpose of having a larger nozzle to begin with.All in saying is I'd rather make a tune change than a nozzel change. Smarter not harder. Atleaat that's what they teach you in engineering school...
Never once denied it wouldn't make more power, it won't be much more and certainly not what the nozzle is capable of.One last time and I promise I will not waste any more bandwidth.
You seem incapable of understanding that reducing pulsewidth on a larger nozzle does NOT produce the SAME power! A larger nozzle can make MORE power run COOLER and have LESS smoke while using NO MORE pump!
This is because it injects the SAME amount of fuel much QUICKER...
Fuel quantity determines your pump demand and subsequently your rail sustained. However, injection DURATION determines the efficiency of that burn, all else constant.
A larger nozzle allows you to run the SAME quantity, with better injection window timing. And by dumping the excess and DETRIMENTAL pulsewidth on the end, you would simultaneously stop running his single pump into the ground, regain a proper rail to pw ratio possibly make even more power than he's making now if rail's dropping horribly, or worse case only lose a bit of power compared to where he's at now while bringing EGT right in check, costing nothing aside from some time on a keyboard and requiring no work done to the truck.
In fact, truth-be-told, he would probably be better off with a small charger setup if he had BIGGER nozzles than he has now!!! He could shorten the injection window even more and give the fuel even more time in the hole to burn with the available air!
This holds true to the point where the larger holes eventually produce such large droplets that efficiency starts to drop again for that reason, or when in the process of making the holes larger, the efficiency of the hole to atomize fuel is killed, like with EH where the hole is smoothed out too much and you get to much laminar flow instead of the turbulent flow needed to bust the fuel up.
If a larger nozzle can make the same power as a smaller one while smoking less, using less pump and running lower EGT how do you figure that would be "treading water"?
Lowering EGT, raising rail pressure and controlling smoke are important things. Millions of dollars have been spent toward those goals alone.
What you're missing is its a waste of having the larger nozzles to begin with. Why live with only a fraction of what it can do and call it good? Why not follow through and do it right? Maybe my work ethic and pride in workmanship is higher that yours I dunno. But if it were me I'd follow through all the way.
Besides, what other big power 6.4's are running around out there under aired with their PW dialed way back to make it livable?
I'd have the air to match the fuel and make it just as liveable and run much stronger. Unless I missed it I didn't read any where that he said he was broke and couldn't swing a turbo upgrade. Low pressure drop in's are are relatively cheap and would do a far better job of curbing his egt's and make more power.
I'm done arguing about it, its not my truck. I could care less at this point.
Good night.
Who said that? I'm saying using 25% ( for example ) of the nozzles ability vs 75% of its ability is pointless. Just swap the stock ones on at that point. If you need to dial the fuel back to keep it happy you have either too much nozzle or not enough air. Pretty simple.
The cart was put before the horse, too much nozzle and not enough air to burn all the fuel it can put out. I suggested adding more air to balance it out ( completely logical BTW ) and that makes me a moron.... Got it.Who would choose to run a nozzle that runs hotter, smokes more and makes less power for a given engine setup?
You really are being a moron.
:morons:
Mean while you suggest turning the nozzle down to the point of an almost stock like tune and leave the air situation as is. But you're not the moron for wasting the point in having a larger nozzle ( using its potential ).
So in summary, you say its hot out so put on a jacket. I say turn the AC on and that makes me a fool.
Well enjoy that logic, you know walking through life stubbing your metaphorical toe on everything.
But most importantly, your continued response of just "adding air" totally ignores the fact that he hasn't mentioned the truck being low on power, unless I missed it. He says it's way too hot, especially at part throttle. That is classic tuning. If he said the chargers were really doggy that would be different, but he said they were coming up fine, it's just hot all the time. Classic excess pw.
Secondly, "adding more air" costs money. And time for the hood to be up with things being physically changed out on the engine.
Lastly..... if the problem really is a part-throttle, then a bigger charger setup might actually worsen the issue if they don't come up in the mid-range as well, and it never fixes a mismatch between desired rail vs pw for a given pedal position! Truck would still be smokey and doggy with rail trying to chase the pw all the time. It also would do nothing to fix the extra resources being drained from the injection pump due to the injectors being held open too long!
Money, money, money and never actually hit the real issue, just keep chasing it with hardware.
I know I'd much rather reload a tune over changing nozzles and/or buying and installing a turbo...
Now obviously his upgrade path is laid out, but maybe more mechanical changes aren't available right at the moment? Adjust the tune then add air when budget and time allow.
You're both correct IMO.
