They are at the bottom. It got split up when i went to pdf format to upload it
Try this set up and 1 1/2 turns. Turn counter clockwise until locked and turn it clockwise 1 1/2 turns.
That's how it is hooked up Beefy.
is just my truck but is there way more throttle range when you adjust the pedals closer to you? i thought since it was all electronic, adjusting the pedals wouldnt change the response. but anyways i get way better response with the skinny pedal adjusted towards me.
I knew you wouldnt have my back "anytime" haha. I am not short either LOL. It might the rubber mat. But im sure there is a lot more range when i adjust them. I could be going crazy. But no my boost is still only geting to 41 psi on 345 tune. 310 is less. Pretty sure thats all trans shyt though.Maybe you are too short? Can't push the pedal all the way down when they are not set up closer? hahaha That is the reason for the low boost, not getting WOT!
at the track i usually adjust them up a little its easier to push the peddle full bore and its usually a bit easier for me to spool and have throttle control. My nitrous is mounted to the bracket so it moves with the pedal so keep that in mind if your nitrous is set of a WOT switch
