E40D to 4R100
Vogel469
What is needed for this swap to have the 4R100 shift correctly in a obs
Vogel469
Front pump shift solenoids and shift lever shaft from e40d.
Swap all that over from the old trans and it's good to go? What torque converter do I use one from a 4r100 or e40d? Or does it not matter
Vogel469
I got one for free and the e40d in my truck now is starting to slip pretty bad
hucorey
Defiance, Ohio
4r100 has the cast 4x4 adapter vs E4OD is aluminum. Some also require an updated plug for the solenoid pack.
Vogel469
So do I need to switch to the aluminum one or will the cast one work?
