Ebp sensor threads
Mesa, AZ
Anyone know what size the flare fitting is on the late ebp sensors? It’s looks like an, but it’s bigger than a -4, and smaller than -6, and I don’t think they make -5. Put an extra ebp tube on my truck to monitor actual ebp, and need to adapt to 1/8pipe for a sensor for the edge monitor.
Mesa, AZ
It’s bigger than a 12, that’s the biggest tap in my tap set.
DEEZUZ
NO PUKESTERS
NWI
We are talking about the bubble flare fitting correct?
I just bought a 12x1.25 to run threads on them because I came across one that when removing took the threads and galled them.
That was the measurement I came up with but will 2x check Monday
Mesa, AZ
Yeah. That one. Unless I grabbed the wrong tap when I tried it, it wasn’t even close to a 12. 1/4 pipe air fitting about threaded in, but wasn’t right
TD-5
British Columbia Canada
If I recall correctly it is 5/16 SAE flare. or Dash 5 EP sensor.pngsae flare.png
Mesa, AZ
Thanks man. I had figured -5, but didn’t think they made it. I’ll try a 5/16 flare. Appreciate it!
DEEZUZ
NO PUKESTERS
NWI
The 12x1.25 threads in but is loose.
I stand corrected. I can still clean up the threads in with my tap though. Hmm.
Mesa, AZ
So got my fitting in last night, the 5/16 flare works. Thanks for all the help.
