PowerstrokeJunkie
I think he left the valve seal out. Hoping ol Mike has more brains than that (LOL) but if he did, it would probably do alot to fixing all this crap.
That's called a spanner wrench, you're correct on your assumptions
Same chit.. Oh wait I get the check engine light
I thought everyone tuned that out by now...
So that is where the gate is opening.
Example:
xx Psi spring force + Actual psi on top when it opens = Drive pressure on your setup now.
A few things to check -
- Spring force is not 25psi - Apply regulated pressure to the port on the bottom of the WG. Determine the psi needed to lift the valve.
- Diaphragm has a leak - Apply regulated 30psi to the port on top of the gate to see if it holds pressure.
- Ring on the bottom of gate (where valve seals) is installed incorrectly. - Make sure it is not upside down.
- V-Band clamps are not sealing - Check that the clamps are aligned and check for any exhaust leak in this area.
- WG is faulty - Remove and install V-Band plates to block off opening.
- Turbo has high DP - Install more spring force (stacked springs-smaller diameter in the center).
If the WG is functioning properly then the gate will only open when there is more force pushing up than force pushing down. It's that simple. Keep at it!
Wow item number 1 on the list, how did that test slip by :doh:
Hope it's the spring.
I moved the WG from the rear position to an easily accessible location so changing springs and inspecting is an easy chore with out any bad words coming out of my pie hole.
